Data Roaming - USA
Mitch99
Arrived today. Neither myself or my wife are getting the service we paid for. Data  roaming is on, but although we occasionally see AT&T in the top left hand corner, nothing is connecting. We have tried switching the phones on and off, switching data roaming off and back on. Any ideas?
_MrR_
Scholarly Contributor
Hi @Mitch99
That’s a strange one. The fact that the phones are periodically picking up AT&T would indicate you have roaming active on your account (usually if you don’t, even getting a signal doesn’t happen, you simply get No Service / SOS only)
You’ve switched on data roaming so that should work also. `I assume you have roam further on your account and don’t have any spend caps in place that could prevent anything from working.
When you do have AT&T coverage, are you able to make or receive calls?
Could it be that you’re in a bad coverage area, could a manual roam onto T-Mobile fix this?
