Changing plan on pay monthly
Cori21
Is it possible to change a pay monthly plan to a lower one. I'm paying £35 for 40GB but that amount is not needed. Can I reduce it to a cheaper plan or can it only be increased?
13 REPLIES 13
Contractually you agreed to your agreed monthly payment for at least the duration of your minimum term. You may increase but not reduce.
Profile closed
Not applicable
@bristolian
I've got Unlimited Data, Texts, Calls.
However it will let me change to a lower price of minus £11 with only 2GB Data and Unlimited Calls and Texts.
Not sure if that's correct
Christopher_G
Hi @Profile closed
Was it an upgrade (renewal)?
Profile closed
Not applicable
Hello
I changed Tarriff in November last year so I could get Unlimited Data.  However it will let me change it to a different one but cheaper.  I'm not due an upgrade on my account for the Tarriff.   If I want a new device I've got to pay it off.
Christopher_G
That's really strange, @Profile closed. You shouldn't be able to change to a lower plan whilst in your minimum term.
Coz21
It's a SIM only contract. It started 2018 and ended 2019. Could anyone please tell me the options for SIM only plans, as I can't find anything online. Eg. 10GB, 20GB data.
Thanks.
James_B
EE Community Manager
Hi @Coz21,
If you log in to your EE account and follow the upgrades option, you can view the current range of SIM plans available to you.
Glitteringuls
Been with EE for 3years,  1 year more than I planned and I wish to lower my monthly plan
Chris_S
Hiya @Glitteringuls If you're out of contract, you can change your plan via your My EE account
If you'd prefer to speak to a guide to see what options are available, you'd just need to dial 150 from and EE phone, or 07953 966 150 from any other phone, then select options 1, 4 then 1 again.
Chris S
