Being kicked out of website
MrtnsmrFHP2023
Hi , I use a website for work that holds my data base, when using EE network I keep getting kicked off the website, this does not happen with other network. Does anyone has similar problems ?
I have changed settings and we tried everything.  TIA
@MrtnsmrFHP2023 : Which website is it?
MrtnsmrFHP2023
the website is pps express run by rushcliff
It could be Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
