Add ons
Jlb19721
Can I add on the data roaming for a month and then remove it? Or will I have to keep it ? Thanks
@Jlb19721   You can have it for as long as you like.
You need to make sure roaming is enabled on your account before you go so your device will connect to a local network you can do this now just by texting ROAMING to 150.   It’s free to have roaming enabled on your account and you don’t need to remove this.
