Abroad
sorake
Hi , I use a Bussines sim card, if i going abroad I will be charged if I using mobile data? or I can use my UK plan?
Alex_M
Star Contributor
Star Contributor
Hi @sorake,
You can text ROAMING to 150 to check that you are all set up to roam in Europe using your plans minutes, texts and data.
If your plan started before 27 October 2021 then it is free ro roam in Europe. Otherwise it's £2/day which is automatically added to your account.
If you're travelling outside of Europe then you will need a business or world passport. Details can be found here.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
