5G disconnects after 3 hours
Ian236
Hello. Has anyone experienced mobile data being disconnected after 3 hours use?
I am using a Netgear 5G router for live streaming, and 3 times now I've lost the internet connection after 3 hours, today it happened after 3 hours, then again right on 6 hours.
The SIM isn't on a data only plan, it has call and text allowances - just wondering if this is something that can happen if it's not a data only plan.
Thanks!
7 REPLIES 7
Katie_J
Hi @Ian236.
Thanks for coming here.
How much data does your SIM have?
Does this happen the same time of the day or is it simply every 3 hours of streaming?
Katie
Hello Katie,
It’s an unlimited plan and the issue has been at different times of the day.
The signal strength still looks good but the connection appears to drop completely.
Ian
Katie_J
Thanks for getting back to me @Ian236.
Are you able to check the SIM in another device to check if there has been any high usage texts from EE?
Katie
Hi Katie,
I’ve just put the SIM in a phone, no high usage alerts received.
Ian
Katie_J
Thanks for checking @Ian236.
If this continues I'd recommend giving us a call.
Our technical care team will be able to complete further diagnostics.
Katie
Hi Katie,
Thanks. I will call them as I don’t want further instances, it’s happened enough already.
Thank you for checking.
Ian
Leanne_T
Let us know how you get on @Ian236
Leanne 🙂
