£36 1 month contract unlimited sim only
Chenwaa72
Hi.
Due to the fact that I have to move out temporary so I bought a £36 unlimited sim to put inside my 4G sim route device to use.
The first week thing seem normal eventhough the speed isnt fast like they claimed but I am fine with it.
However until today (1week after) the uncapped (fastest) speed they said went from 60mbps (using speed check) down to 2-3mbps which is unaccepted.
I am barery able to do anything with it
I check the area if there any line issue but they reported back nothing. how can I solve this problem or this is how EE is and I should do a refund?
(TS18 area)
@Chenwaa72  Have you tried relocating the router to a different location?   Placing the router next to other equipment can cause issues.
Hi. I did try to move it around. including put it outside of the window. but nothing changed.
I mean even that, It didnt have any issue before with that placement. why is it happen 1 week after
Are those speeds consistent regardless of time of day, day of week etc?
Any restrictions based on usage would be - whereas traffic-related slowdowns would vary.
EssexBoyEE
Unlimited Data Sim Plans have a Data Fair Use Policy (FUP) which is normally 600gb per Month, have you exceeded this amount as this will potentially cap your Speeds until the next Month.
I do aware of that. only used 50gbs so far
