2 lines switch data
taryngerlach
When i took my newest contract out, to get me the cheapest deal the guy in the shop took out an additional line with data on (this is a SIM only) he said if I run out data on my normal line, i can go into the app and switch to the SIM only line. I can’t seem to find out how to do it as when I click the additional line and go back into the app it comes up with my main line. Am i doing something wrong or just being stupid? lol thanks
You can choose which of 2 SIMs are "primary" for data, voice & text using your phone's settings menu. Both lines will be active for incoming voice & text.
The exact location of this menu varies between Apple & Android.
Apple - https://support.apple.com/en-gb/guide/iphone/iph9c5776d3c/ios
Android - https://www.samsung.com/uk/support/mobile-devices/how-to-use-or-manage-dual-sim-cards  or https://www.asurion.com/connect/tech-tips/dual-sim-cards-android/
Oh, I took it that the OP was on about data gifting. Hence the referral to the app. Is it common for 1 phone to hold 2 SIMs from the same provider?
Perhaps the OP could clarify what they've done - I took the comment "additional line" as meaning a second SIM.
Using 2 SIMs from the same network certainly isn't unusual if it's for pricing or differential (work/personal) reasons.
