how to register sim card on mobile internet
jasoncrooks
Is it on contract or PAYG?
MyEE doesn't work for registering PAYG MBB devices or at least those with data SIMs. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your device but you just can't register it to MyEE.
  1. Use Fast Top Up online with a UK bank card. You don't need to login or register anything. All you need is your mobile no.
  2. Go to http://add-on.ee.co.uk/status from the device will tell you your usage.
  3. Go to http://add-on.ee.co.uk/purchase from the device to buy add-ons.
These should still work.
Madbattyb17
I’ve got new sim but cannot register
I’m on contract
Leanne_T
Hi @Madbattyb17
What was the reason for the replacement SIM card?
Leanne 🙂
