on 03-03-2023 03:56 PM
How do you change WiFi password
Solved! Go to Solution.
on 03-03-2023 04:12 PM
For which router?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
For which router?
