06-05-2023 08:33 PM - edited 06-05-2023 08:35 PM
I was trying to pm user @XRaySpeX as he/she seems knowledgable, but this forum doesn't support it
I am trying to find a router that I can disable wifi and just use the cellular via the ethernet / usb connection...
06-05-2023 11:03 PM
Most routers you can disable the WiFi. For instance the 4G WiFi
