Using 5gee wifi aborad
leblah
Hi I'm going on Canada and I'd like to take my mobile broadband 5gee device. It is a business device and I see from here that you offer a Business Daily passport.
Roaming | International Business Mobile Plans | EE Business
To enable it I need to text PASSPORT to 150. However, I'm unable to send a text from the 5gee device.
Can you advise what i should do
Thanks in advance
6 REPLIES 6
Most mobile routers do texts. Does it have an envelope LED showing on it?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then look for the SMS section.
Thanks for your reply.
I have logged in but it only allows me to read messages and not send them.
Duh! It only has a cut-down SMS.
James_B
EE Community Manager
Hi @leblah,
Have you tried setting up the add-on in My EE?
Hi James,
Yes I tried that but no luck.
In My EE on the Addons page there are two addons already applied. 1 is called Wifi Coverage Boost and the second is £2 per day for EU roaming.
Under the section titled "get more addons" there are no other available options.
James_B
Thanks for checking @leblah
I'd recommend getting in touch with Business Support who'll be happy to setup the passport for you.
