Use 4Gee Wifi Mini without the battery
ArthurWellesley
The quick start guide for the 4Gee Wifi Mini says ... "If you intend to use your 4GEE WiFi Mini whilst connected to your charger for more than 7 days, then, it is advisable that you remove the battery to avoid any potential demage."
I want to do just that, and avoid the battery overheating.
But when I remove the battery and plug it into the charger, I can't connect to the wifi.  The device disappears from the list of available networks.  All lights on the device are lit.
I see the SSID of the 4GEE WiFi Mini with battery removed.
What are you using as the charger? Is it the USB connected to a PC, which makes a quasi-Ethernet connection?
No, not plugged into a computer.  The cable is plugged into a USB socket running from a 12V system on a caravan.
Did you ever get an answer to this? I’m also having the same issue
I’ve been using a EE mifi mini router for the last year now without problem.  Battery is removed, and with USB plugged in, running off the caravan’s 12v system.  Works well.  Sometimes takes a few minutes to find the WiFi.
Only downside is, for the USB sockets to be live, I need to leave the master switch of the caravan elecs switched on.  This draws a surprising amount of the 12v  battery, or at least much more than the router would otherwise draw on its own.  A  roof solar panel keeps it topped up, but ideally it needs a direct feed from the 12v battery so the master can be switched off.
