on 28-05-2023 09:19 AM
Hi there. Ive just got my 4G router. It was working perfectly fine then this morning a constant red light on the box shows. I can’t get access to the service I’m paying for. Any help please as I’ve tried the reset button etc and nothing works.
on 28-05-2023 12:45 PM
Hi @Arron881
Welcome to the community.
Are there any maintenance works in your area? You can check by popping your postcode into our coverage checker and hitting 'check status'.
