Re: 4G EE Home Router (2017) is substantially slower than my iPhone 13 Pro Max 4
HirokiS
Suffering from exactly this and it's affecting my work.
4G on my iPhone 13 Pro Max is significantly faster than my 5GEE router on the 4G network. Both devices are in the same room.
I don't think I can justify £50 odd for this, which is a shame because when it works, it works great!
Leanne_T
Hi @HirokiS
Is the iPhone also on EE?
If so, are you able to try the SIM card in the iPhone from the router to see if you have the same speed?
