Problems with 4G Router
Santyjazz
Hi all,
I have a TP-Link MR6400 4G Router working with my EE Sim. It worked perfect, very smoothly until, silly me, I decided to test the router with a SIM from another company. Well, this router apparently detect any SIM and details. It did it the first time with my EE Sim and worked with zero issue but it is enable now to recognise that other company SIM and the worse scenario happened: when I put the EE SIM back the router didn't recognise it. 😞
I tried to get things back doing the usual, rebooting and also I set the router to fabric configuration but no joy. It's unable to recognise now the EE SIM, asking me for a user and password that I don't have. I tested the EE Sim in a phone and the 4G works without issues so I am very frustrated and confused here. Why it's not recognising the EE SIM now? Silly me for trying with another SIM company but as I said, this router apparently detects any SIM and details.....
Any ideas, any help, someone with similar issue with this or other 4G router? Thank you!!
You probably need to change the Profile/APN to fit EE by using some of the settings given in EE APN Settings: Where to find them altho' it should have found them itself when the EE SIM was inserted & the router rebooted.
6 REPLIES 6
Santyjazz
Hi XRay,
I am not using this one in a phone just for having internet in my place where we don't have great internet speeds but I'll insert the SIM on my iPhone and I'll check the APN settings.
Although as you said, the router should be able to set this automatically as it did initally but not now. I am contacting the seller for a replacement but they should sell this crap, to be honest, 3 days working and caput, zero, nada..... it's very frustrating.
Thanks for your help!
Cheers!
The APN settings are not on the SIM but in the device itself. On a mobile router it's called the Profile. You look at the default Profile & if it doesn't fit EE you create a new Profile with the correct APN settings & make it the default.
There's almost certainly nowt wrong with the router to contact the seller about. This misaligned Profile happens quite a bit with mobile routers.
Santyjazz
I've finally bought a new 4G router and return the previous one and the new one is working wonders. All good by now and I hope it'll continue this way. Thank you for your help @XRaySpeX !
Cheers!
Ace171
I have similar issue with Huawei 818-263, bit long post but for history: Live in area where max wired BB is 17Mbs so as my IPhone 15 pro with UW supplied EE unlimited data gave me 40Mbs I thought I would try a 4G router. Tested first with Lebara (Vodafone I think), not data only but standard phone SIM) very cheap for 3 months then rises to £25pm, worked including connecting to Sky Q box, Bose Wi-Fi speakers and Wiser home central heating control system via my BT Wholehome discs, but not much better than 15Mbs so ended auto renew and got similar deal with Lyca (EE) worked well for 3 months at up to 50Mbs slower at peak times or during wet weather!! then just stopped, so I put in my iphone UW SIM while thinking about what to do, all worked well So thought I would get another UW SIM but needed the iPhone to work as I was going away for a couple of days but wife works from home and wanted to stream content from Sky, Netflix, Amazon Prime etc while I was away. So I but back the Lebara and reactivated for £25 for the month, again all worked well but slow and sometimes spooling streaming. UW offered me an upgrade to 5G on my iPhone plus 3 others for family phones (£23 plus £8pm for others) plus extra one which I was going to put in the router, not arrived yet so re inserted mine. However, can connect to WiFi from all phones but will not connect to Sky, Bose or Wiser, Sky box says connected to WiFi but no internet. Huawei App says APN has correct EE setting.  Any ideas please.
