Password
Prendie1
How do I change password for dongle
8 REPLIES 8
@Prendie1 : Presume you mean WiFi pwd. Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
Password I put in is not being recognised
Leanne_T
Hi @Prendie1
Have you tried admin as the password?
When you removed the battery cover is there another password showing?
Prendie1
How do I change password on WiFi mini dongle
Hi Leanne,
password i want to change is one that was on cover for hub, as i can never remember one that’s on the cover
The password i want to change is the one on cover of dongle
@Prendie1 : There are 2 pwds on the label on the router, the WiFi pwd & the admin pwd. Which is it you want to change? I've already told you how to change the WiFi pwd.
Which router do you have anyway (read its label or post a pix)?
Leanne_T
Hi @Prendie1
Thanks for coming back to me
Please follow the advice from @XRaySpeX to change the WiFi password, if this is not the password you want to change please let us know 🙂
