on 14-05-2023 01:33 PM
My internet connection gets randomly cut at least once a day. is there any way of continuously monitoring either my laptop's connection to wifi or the wifi's connection to the internet, so i can work out where the problem lies?
on 14-05-2023 03:34 PM
Welcome to the community.
Which router are you using? Does it seem to be around the same time that it happens?
on 14-05-2023 04:03 PM
Hi Chris. thanks!
i'm using the new 5G mobile broadband router and no there doesn't seem to be any particular pattern to it
S
on 15-05-2023 08:02 AM
OK, thank you @SteveLinford
Could you pop your postcode into our coverage checker and hit the check status button please?
on 15-05-2023 12:58 PM
Hi. It says no known problems in my area. It's either the router crashes / loses connection (which is my gut instinct ) or My Macbook wifi connection falls off ( less likely in my view ). But I don't know how to prove this and I don't want to just pay out for a new router.
Thanks so much
on 15-05-2023 01:21 PM
Thanks @SteveLinford
Have you spoken to our technical support team? They may be able to help figure out what's causing the problem.
