Mobile signal booster
weimarana
Hi
we live only a quarter of a mile from our ee mast but there are many trees in between so signal strength at our homehub is very dependant on weather, leaves on trees etc.  it varies between minus 95 and minus 115.
most of the time this is OK for SD TV and internet but we have just bought a 4k tv and we get some buffering.
what is the best way to increase the signal received from the mast?  Will adding lte "ears" to the homehub help? If so is there a standard lte aerial suitable for homehub?
Are external aerials a better option? If so what is recommended?
cheers
john
@weimarana  Do you a port on the hub to actually connect an external and internal ?      Can you post a picture of the hub ?  Front and back
Hi
It is a BT Homehub ( on a EE contract, which is confusing).
It has a USB and two LTE screw in ports on the back.
Photos attached.
Cheers
John
No photos are attached!
Use the Camera icon above your text to upload an image file to here.
