Mobile number
sheena1234
Hi, when I brought my mini wifi hub it had a mobile number connected to it - I only brought it to use the preloaded data so I didn't pay much attention to the number. I have now lost the box with number written on it! How do I find out the number please as I need to check how much data I have used? The little hub works so well, very pleased with it so will want to top it up if I can.
@sheena1234  Put the SIM card in a phone and make a call to another mobile phone.    Or login to the router as a admin user.    This information is on the inside of the battery cover
EssexBoyEE
If your using the Sim in a WiFi Device or Router then whilst using a Phone / Laptop /  another Device through the MiFi go to https://add-on.ee.co.uk/status it should tell you your Data Allowance remaining against the Sims Phone Number in the MiFi Device or Router.
@sheena1234 :  Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
Don't use "https:" instead of the "http:" or you'll get "Forbidden"!
