24-12-2023 03:08 PM
Hi any one had any issues with the 4g mobile not working when plugged into the socket but sims to work when plugged into the laptop?
26-12-2023 09:15 AM
Morning @Kev134
Which device are you using?
What happens when the device is not plugged in and you try to use data?
Leanne 🙂
05-01-2024 08:41 AM
Hi Leanna
Just the mobile broadband Wifi which has been working absolutely fine but for the last month. Basically what happens when i first plug it in and connect to EE works great but when i stop using it, it stops working so have to restart it? This has only happened in the last month!
05-01-2024 08:59 AM
Thanks for coming back to me @Kev134
Have you tried resetting the device using a PIN in the reset button?
