Mast down for 10 weeks
CindyA
We suddenly lost our signal on 3 September which we also need for 4G broadband as there’s no other broadband option here.
My mobile doesn’t work and my broadband speed is less than 1 mbps, when it’s working. It hardly works at all evenings and weekends.
EE is non-committal about when it’ll repair the mast and there are at least two others down in this area of Carmarthenshire.
Does anyone know how long this repair can possibly take or whether EE could just not repair it?
Christopher_G
Hi @CindyA
Welcome to the community.
If you pop your postcode into our Coverage Checker and hit check status, it will tell you if we're aware of a problem and give you updates on how long we think it will take to fix.
I’ve already done that many times starting on 3 September when my service stopped and I have also been in touch with EE many times but have not had any indication of when it’ll be fixed. BT told me that there are 3 masts in my area that are down.
Your coverage checker indicates as it has from the beginning that it’ll be fixed in 16 hours. That 16 hours has expired over 100 times.
Again I ask how long customers have to wait for a mast to be fixed and whether EE just doesn’t fix them.
Northerner
Hi @CindyA
It depends on the issue. You cannot buy network parts on Amazon, they are bespoke systems which could take months to deliver.
You'll just need to keep checking.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE wlll usually repair the vast majority of easy faults in a couple of days, but the ones that take longer tend to have complicated underlying reasons. Perhaps there's an issue with or involving a third party, maybe there's a specialist part - there could potentially be legal or technical complications.
No fault intentionally goes unresolved, believe me. Out of interest, what area (roughly) are you in?
Thanks for this reassurance. I’m in rural Mid Wales where the fibre optic project that was started 5 years ago wasn’t completed.
