MacBook won’t connect to 5G smart Hub
GG597
we have a 5G smart hub for our shop. We have a iPad, iPhone that all connects and works fine to the hub but the MacBook Pro just won’t connect.
it picks up the hub in the WiFi and connects to it then drops out almost immediately. MacBook has latest software update, tried turning everything off and on again and nothing works. It just won’t connect and stay connected. So frustrating as everything else connect and works just fine.
Any ideas?
15 REPLIES 15
Tried it and didn’t work.
Thanks anyway for the info.
Yeah that’s all I done in the DNS section of there is a + click that and add the DNS and it worked
Think I’ve done it!
I took the same DNS settings code off my iPad that connects fine to the hub and put that in on the laptop DNS settings.
No drop outs yet.
Thanks so much!
Do you have another computer that you can check to see what the DNS settings are and try that I don’t know if the settings are unique for each router
Thank you so much! I was experiencing the same issue and your method solved my problem! Maybe I'm over-concerned about this, but just want to double check that you don't see any other network drops since you changed the DNS address.
Thanks and regards,
Hey no I hadn’t had any drops from anything else
