How do I get other people connected to our WIFI... the password and QRcode fails
CBone123
We have had people over  during the Christmas holidays and they are unable to connect to our MOBILE BROADBAND even with the password and QR code ... how can this be solved ???
CBone123
this is exactly what it says for my visitors and it is very frustrating .. have you resolved this issue ?
@CBone123  Have you changed the password from the default one.   If you have the QR code isn’t going to work.       If you haven’t changed it just try switching off the router for 30+ seconds and rebooting it.
Hi there
 we haven't changed anything and we give people the password to type in very carefully and even after several trials it doesn't work
Just been on to Technical services and they say it is NOT their Hub but with all of the other people's devices... but if it is any NEW device I cant understand how that can be the case ?
so frustrating even tried taking the SIM card out of the router !
You're not giving peeps the admin pwd instead of the WiFi pwd?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear where you can check it char by char.
If rebooting it doesn't fix it try Factory Resetting it. A pin in a pinhole somewhere on it for 5 - 10 secs while powered up.
