15-04-2022 06:17 PM
15-04-2022 06:50 PM
Hi @RussellZ
Log into your router and then under WiFi you can change your password.
15-04-2022 07:04 PM
Thanks @Northerner but how do I do that. I don't have an EE Router, just an 4GEE mobile wifi device.
15-04-2022 07:09 PM
Hi @RussellZ
Try entering http://192.168.1.1/, then press Enter.
What is the mobile device you own?
15-04-2022 07:28 PM
Thanks @Northerner
That's not working. "problem loding page".  I will try again later.
The device is a 4GEE Mini
15-04-2022 10:52 PM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
16-04-2022 06:22 AM
@XRaySpeX
Thank you for those very clear instructions.
Sadly, I just cannot log in to that address for some reason and so I am now resolved to living with the over-complex original EE supplied passkey.  Thanks for your help. Much appreciated.
Russell
16-04-2022 06:27 AM
Why can't you login to it? What happens when you try?
