on 11-04-2023 11:31 AM
I am on the 4GEE Home Unlimited £50 plan however every month I receive a message that I have 'run out of data' and switched to a reduced data. When I go to date usage it states we have used 100gb of 100gb data but I am paying for an unlimited data plan, I'm confused?!
Can anyone offer any advice?
Thank you.
Solved! Go to Solution.
on 11-04-2023 11:42 AM
It won't have said you 'run out of data'. It's only talking about data that you may potentially gift from the 1st 100GB of all your data to other nos. on your a/c if you choose to. It's just a warning just in case you wanted to. You may safely ignore it & carry on using data for your own purposes including hotspotting.
As you use data for your own use you are eating into this gifting allowance even when you are not actually gifting it.
on 11-04-2023 11:36 AM
