Blessings2023
Hi
Travel overseas and forget to send ROaming to 150. Is there anyway I can get it set up? I try sending a text but to no avail. I have an urgent call to get at 2pm please help
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
