Help with usb key
CHOLLOBEREN230
I'm trying to use a sub stick from ee for info about a fone I'm paying for it keeps asking for password I have put in my password won't accept it can anyone help
CHOLLOBEREN230
CHOLLOBEREN230
What a ridiculous site absolutely not needed. I have a usb stick from ee it's impossible to access no help whatsoever. Cancelling we going to o2
@CHOLLOBEREN230 : Which pwd is it asking for? Which pwd have you put in? A mobile router does not work off your MyEE pwd.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
