Forced "Change your 5GEE Router Wifi SSID and Password" otherwise no internet
Kristinai
Hi all,
I am having a problem with our 5GEE router.
Last week the internet stopped working and the message "change your 5GEE Router Wifi SSIS and Password" so I followed the instructions, the message went away and we got our internet back.
Today the same message has popped up - but this time even though I have changed the name and password 3 times each time I reconnect after changing it there is no difference - the message is still there and we dont have internet access.
Have restarted the router a few times
Getting desparate now as a few of us wfh and we need this sorted
Thanks in advance
17 REPLIES 17
EssexBoyEE
Are you still able to login into the Admin Area and view your settings?
Hi EssexBoyEE,
thanks for replying
yes I am able to go in and make changes
OK, after login go to Status Page then Internet.
About a few lines down there should be something like Connected, click to disconnect wait about 10 seconds then click on Connect.
No joy unfortunately
When I arrived on the status page it already read “disconnected”
When I click ‘connect’ it just says “Connecting…” but nothing happens
Can you send me or post up a Screenshot of the Status Page (the whole Page, to include the Signal Info) , delete any personal info like phone number or IMEI if not, just PM it to me.
OK, need to wait now for the pic to be approved by a Mod or Admin.
While we are waiting for Pic approval, if it stated Disconnected, hit Connect, wait around 10 seconds, then do a Hard Reboot (hard means doing a Power Button or Unplug then Power Back On).
Is there a Profile page? May we see it?
Is it on contract or PAYG?
