Flashing mifi EE70 factory firmware
smp_ann20
How to reinstall/flashing unlocked Mifi EE70 device to the factory firmware installation? its said default password web login device is invalid while I tried to reset by pressing reset button. SSID has changed to default but unable to connect because default password is invalid. So I connect using USB cable to gain web login to 4GEE WIFI.
James_B
EE Community Manager
Hi @smp_ann20,
Are you using 'admin' as the username and password when logging in to the console?
@smp_ann20 : Even via USB you still need the admin pwd to login to the router. You sure it's not the WiFi pwd you're missing?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
