03-09-2022 05:36 PM
Hi there,
Recently having issues with my BT 4G Router...when the ethernet cable is connected the internet connection is lost (light goes from blue to green)...when the ethernet cable is removed the internet connection picks up again (light goes from green to blue). Anyone else have experience of this or can suggest possible solution please? Thank you, S
04-09-2022 07:58 PM
Yes, since trying that (connecting directly to desktop and different cables) it appears the issue may well have been the netgear switch, which I have replaced.
03-09-2022 05:39 PM
The Ethernet cable being connected to what?
03-09-2022 07:22 PM
Ethernet cable from rear of router to netgear switch then ethernet to desktop.
03-09-2022 07:54 PM
What happens when you connect to the desktop directly?
Have you tried different cables?
04-09-2022 07:58 PM
04-09-2022 08:04 PM - edited 04-09-2022 08:06 PM
Glad you got it sorted, thanks for letting us know
