4G Broadband speeds...
hosta93
Hi there,
Broadband speed tests are giving very varied results from my BT 4G router.  EE Coverage Checker gives good 4G indoors and outdoors for my postcode.  Speeds range from 10 to 40 Mbs, but frequently drop off to less than 4 Mbs which is causing problems for streaming etc.  Is there any way of achieving the higher speeds more consistently.  Is this a common problem? I have tried different locations etc for the router but same results.  Speed tests are being carried out through an ethernet connection direct desktop to router.  Any advice or suggestions would be much appreciated.  Thank you.
James_B
EE Community Manager
Hi @hosta93,
Does the Network Status Checker show any problems in your area?
Status checker shows no issue for this area.
James_B
Thanks for checking @hosta93
Please get in touch with Technical Support so a member of the team can take a detailed look at the coverage in your area.
They'll be happy to help. 🙂
