26-05-2024 10:50 PM
we recently got a new EE wifi box and ever since our skyq cannot find an internet connection. After reading posts online I changed the IP to v4, it said i had to disconnect to change this to my default and when I disconnected I then couldn’t get my box to reconnect with the light constantly orange. I reset the box and our skyq box started working! This lasted for 10 minutes and then all of our devices disconnected from the wifi and couldn’t reconnect. I had to switch the box off and on again to get our phones to work and when I’ve logged on it’s reset to the V4V6. Can anyone help please?
27-05-2024 08:59 AM
Morning @fayegill123
Which model WiFi device do you have?
Can you connect the Sky Q to any other WiFi connection?
27-05-2024 09:03 AM
Hi Leanne
It’s a smart 4G Hub.
We have no other wifi to connect the skyQ box to. It definitely seems that the IP being V4V6 is the issue.
Faye
27-05-2024 09:19 AM
Thanks for the quick reply @fayegill123
If you get in touch with our tech guides they will get this looked into for you. Please call us on 150 from an EE phone, or 07953 966 150 from any other phone 🙂
