EE mini hun
Jez1976
I’ve recently purchased a mini hub I’ve had the £30 rolling contract and put the pay as you go sim in? I’ve connected it to my iPhone and Amazon Firestick it’s saying enter password??? Where do I get the password from to make the ee mini hub connect to phone and Amazon Firestick????
@Jez1976 : The WiFi pwd should be found on a label on the mobile router. Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
