EE data upload speed.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
18-09-2023 07:22 PM
The phone line out to where i live is shockingly poor so i use a data only sim from EE in a 4g router.
for ages this has been fine with functional upload and download speeds but recently the upload has become near non-existent.
any known cures for this or is a different provider the next option? as i said until this last week or so there have been very little issues but upload speeds of 0.1mbps at times isnt acceptable.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
19-09-2023 08:34 AM
Hi @4ngu5,
Does the Network Status Checker report any problems in your area? (Please select the Check status option)
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-09-2023 10:48 PM
Hello all I previously posted the following text before trying to get in person help from EE. Today after a 3 hour long round trip I was almost immediately told to phone customer support without a second of thought given to the matter at hand. the previous post was -
"The phone line out to where I live is shockingly poor so i use a data only sim from EE in a 4g router. For ages this has been fine with functional upload and download speeds but recently the upload has become near non-existent.
Any known cures for this or is a different provider the next option? as I said until this last week or so there have been very little issues but upload speeds of 0.1mbps at times isn't acceptable."
I'm sure we all know this wont be fixed over the phone. I have screenshots proving that 1) according to OFCOM's website EE service isn't available indoors or outdoors at my home address and 2) that a Vodafone SIM in the same 4G router provides quite literally 5x the speed at times.
What can I do to escape this SIM card situation? or at least get the EE speeds back to "normal" which is still subpar at best.
Thanks for any help.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-09-2023 11:15 PM - edited 28-09-2023 11:17 PM
@4ngu5 : Then why not continue your existing thread instead of starting yet another? & why not try @James_B 's suggestion?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-09-2023 11:43 PM
coverage checker asks for a mobile device which I cant answer as I don't use one in this case.
For arguments sake I just checked with the 3 popular devices provided all of which result in
"You'll get great coverage outdoors and good coverage indoors."
Which clearly isn't true.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
29-09-2023 08:05 AM
Hi @4ngu5,
If you start typing 4G WiFi into the box, you should see a mobile broadband device.
To check for problems, please select the 'check status' option. If there are no known issues, please use the 'report a problem' button.
Hope this helps. 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-09-2023 01:58 AM
Again using other 4G routers shows I should be getting fine coverage on the map.
I have reported the fact that EE speeds are prehistoric so we will see what that results in.
I will be calling customer service tomorrow as this is unusable and I have already tested Vodafone as a replacement. I just need to figure out how to stop paying for a service that quite literally doesn't work at times.
- Erratic mobile data speed in Mobile Broadband
- Mb/s drops to less than half of guaranteed speed in evenings in Broadband & Landline
- Slow speeds in Broadband & Landline
- Positive experience of upgrade from 900Mbps to 1.6Gbps with Digital Voice in Broadband & Landline
- Speed drops from 550Mbps to 40Mbps in Broadband & Landline
