13-10-2022
10:46 AM
- last edited on
13-10-2022
11:06 AM
DanielPA
1. Why can I not add this device to my account?
2. Why can I not see how much (of the very expensive electrons that I've bought from you) are left?
JHS
13-10-2022 11:59 AM
@JoeStoner : MyEE doesn't work for registering PAYG MBB devices or at least those with data SIMs. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
You may continue using your device but you just can't register it to MyEE.
These should still work.
