‎18-01-2024 02:32 PM
Any one can help me disable ipv6 on my router (5GEE)?
‎18-01-2024 05:24 PM
Hi @Isaaziz
Thanks for coming here.
Is there a reason you want to disable this setting?
Are you having problems using the router?
‎18-01-2024 08:53 PM
Try changing the Profile/APN on your mobile router to APN Protocol = IPv4 only.
‎23-09-2024 04:52 PM
@XRaySpeX I have a Smart-4G-Hub. How do I actually change the Profile/APN on your mobile router to APN Protocol = IPv4 only? Is this done in the hub manager settings?
Thanks.
‎23-09-2024 07:37 PM
@BB441 : Login to it & look for Connection Profile.
‎24-09-2024 01:46 PM
I have posted a thread on this issue in the last couple of days.
