5g hub
Andrewneal17
Hello
a
l am considering a move to EE 5g WiFi at home as fibre is not available in my area, am I right to assume that the 5g speed on a new hub will be the same as on my EE phone?
7 REPLIES 7
@Andrewneal17 : It should be for like-for-like SIM plans but don't be surprised if it isn't.
Ok thanks
so what might be different in the hub sim?
Diff SIM plans may have diff speed limits, usually Uncapped, 100 Meg, 25 Meg or 10 Meg. It would have told you when you bought it & it may be recorded in your EE a/c.
I’m uncapped on the phone
what should I expect in the hub sim ?
You're talking a SIM that already comes with a mobile router? Depends on what you buy. It should tell you when you buy.
Ok thanks for your help
it looks like the EE 5g router on an unlimited plan is uncapped
Good!
