5g hub purchase
Go2Matt
Does anyone know if i can purchase the hub in store for immediate use or if it has to be online and a few days.
After 3 months of waiting for BT/Openreach to install theyve just cancelled which means no internet (we were using the 4g backup)
Northerner
Hi @Go2Matt
You might not get the same deals as you'll get on the EE website. Plus if you search EE 5G router on Google you can likely buy the router online and then get an EE data SIM which save you money in the long run.
Decision is with you.
