5G/4G router
thusband
Valued Contributor
Valued Contributor
We've had our phones with EE for several years now and are interested in getting a 5G/4G router for our home network but the only router I can see only has one port. I need a router like our current one that has multiple ports for several Ethernet devices. I know EE offers them but I can't find them.
We're in Somerset and it looks like 5G is available outside. I've read that there are outside antennas that can be installed to pick that signal up. We have an antenna on our current system (Voneus). I realise that antenna won't work but can one be installed to pick up 5G?
Is there a link that would give me information on routers/plans available and outside antennas?
Many thanks for any hints.
1 ACCEPTED SOLUTION
Northerner
Hi @thusband
See here: https://ee.co.uk/broadband/mobile-broadband
Antennas: https://store.ee.co.uk/category/networking,network-devices,accessories-and-modules/11182?Type=Antenn...
You'll likely need to use a switch to give you more ethernet options.
Northerner
Hi @thusband
thusband
Valued Contributor
Valued Contributor
Thanks, that's what I was looking for. My current router has multiple LAN ports but I also use a switch with it. I guess EE wouldn't install the antenna right?
