4gee Flashing network green light
petedakilla
Hello,
had this 4gee router for nigh on 2 years and have been unable to access internet 4 2 days after being shown a ‘flashing green light - NETWORK’. Tried several resets but to no avail. Checked network coverage which shows no local issues?
any help/advice greatly appreciated.
Christopher_G
Hi @petedakilla
Do you have another mobile device? If so, is the data working OK on that?
No.
Do not have another EE device.
Leanne_T
Hi @petedakilla
Are you able to try the SIM card in another device to see if you can connect to the internet?
Leanne 🙂
tried sim in my iPhone. Shows network connection (top left) but won’t connect to the internet???
Christopher_G
Thanks, @petedakilla
It may be worth speaking to our technical support team to see if they can look into this for you.
