4g Hub and Smart Hub
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 11:25 AM
Looking to get one of the 2 4g hubs but need this for gaming do both have ports for an Ethernet wire?
I can see the smart one had an ethernet however does this need a wired connection into my home or is this also through 4g signal?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 04:54 PM
The 4G Smart Hub just connects to the mobile network & you're good to go.
Unless you are referring to the Smart Hub for fixed line BB. You've just used "Smart Hub" throughout. Just which device are you talking about? There are many varied such things called that.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 12:59 PM
- The 4G WiFi router will be battery powered with no Ethernet ports.
- The 4G Smart Hub will be main powered with probably 2 Ethernet ports.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 04:44 PM
Does the smart hub require a wire into the house for WiFi or is it a case of plug into the wall and your good to go?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 04:54 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 05:07 PM
No was meaning the 4g smart hub my bad think you have helped
just to confirm the 4g smart hub is plug and go and has Ethernet ports?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
31-01-2025 05:16 PM
Yes.
- Connected - No Internet Access in Broadband & Landline
- “Smart Wifi” after moving from BT to EE broadband in Broadband & Landline
- What to replace old BT wholehome disc with after switch to EE? in Broadband & Landline
- USB Printer Sharing in Broadband & Landline
- Having trouble with my router in Broadband & Landline
