4GEE has no wifi
Katiee-123
My 4GEE was working fine then stopped, it has data on it. But will not connect to the internet
1 ACCEPTED SOLUTION
Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
@Katiee-123 : Is it on contract or PAYG?
PAYG
Sent from Yahoo Mail for iPhone
