4GEE WiFi Mini EE771 The battery percentage does not display correctly
Alidamiri
hi there
 i recently bought ee71 WIFI mini and The battery percentage does not display correctly in the management panel
for exampel The percentage of the battery shows 20% and after some time I visit it, the battery has increased to 30%.
And when it turns off with no battery and I charge it, it starts at 50%. I think it is a software problem
 Software version:
EE71_E1_02.00_38
Lesley_W
Hi @Alidamiri
Welcome to our community.
I'm sorry to see you're having a problem with your battery percentage. Have you noticed this issue since you first got the device?
Lesley
Maestro
Maestro
@Alidamiri It will be to do with the load power when device is on or off, nothing to do with software issue.
