4G wifi dongle not working
jim-barney
I have had no problems before and i have topped up credit and transferred credit into and add on and says i have 23gb on app but when I turn box on the wifi keeps dropping out?
21 REPLIES 21
Katie_B
Hi @jim-barney
Welcome to the community.
When was the last time your account was topped up before your most recent top up?
Have you been able to check your area for any known issues?
Katie
Hello,
A couple of days ago and before that Feb/March 23.
Kim
Katie_B
Thanks for confirming @jim-barney
Have you been able to check for any known issues within your area that could be causing this?
Katie
Yes i have and nothing going on as far as i am aware.
Christopher_G
If it says we're not aware of any problems, you should get the option to report one, @jim-barney.
Our network team will then look into the performance of the mast in your area and get back to you.
jim-barney
Hi, it still says data waiting but i have no active plans at present?!
Christopher_G
It may be worth speaking to our Mobile Care team, @jim-barney
They'll be able to check everything from our side for you.
I have been onto 4 people today all very helpful until i got cut off. Tried a lot of different things but none of them have worked so far.
Christopher_G
Did they say what could be causing the problem, @jim-barney?
What things have you tried so far?
