01-08-2023 04:54 PM
Despite disabling WPS from the dashboard, the Green light stays on.
How do we turn it off, it is far too bright.
02-08-2023 08:21 AM
Hi @Uberseehandel,
Turning off WPS should also switch off the indicator LED.
Is it only coming back on after a restart?
02-08-2023 10:21 AM
Thanks for getting back to me.
When I turn off WPS, the indicator LED is not switched off.
I've tried turning it off and on and repeating a couple of times, to no effect, sadly.
02-08-2023 10:40 AM
Thanks for confirming @Uberseehandel
Please get in touch with Technical Support so a member of the team can take a look at this for you.
They'll be happy to help. 🙂
03-08-2023 06:13 AM
@James_B
I'll let you know how I get on, once the Tech Support Team has resumed normal services.🤓
03-08-2023 09:29 AM
Thanks very much @Uberseehandel
