13-10-2026 07:42 PM
13-10-2026 08:42 PM
@BC52E What colour lights are on the router when this happens? This is important to know. WiFi is only a signal from the router so is it the WiFi signal that’s dropping out or is the router that’s losing connection as that would cause the WiFi to drop out.
13-10-2026 09:39 PM
@BC52E : Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working? What colours are the light sequence when it happens?
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
