26-06-2026 11:09 AM
I have 2 plugs both run ok . With clear connection To Yellow
26-06-2026 12:52 PM
Hi @LesLesTMZ
Read here: https://ee.co.uk/help/broadband/getting-started/set-up-guide
Always use the ones which come in box and follow the instructions to avoid issues.
26-06-2026 01:28 PM
@LesLesTMZ Then you may need to go buy and adapter if that is going to be required for you!
26-06-2026 01:30 PM
The 2 cables with yellow plugs are Ethernet cables, not phone extensions. You plug your phones into the green socket.
