VR Meta 2
Mary01
Does the VR Meta Quest 2 work on PlayStation 5
Christopher_G
Hi @Mary01
Welcome to the community.
You play the games on the Meta Quest 2 itself. This is what the blurb on our website says:
"Simply put on the headset, draw out your play space and start exploring fully immersive games, fitness, social spaces and entertainment. No PC or console needed.**Requires mobile device, wifi and companion app for setup."
I believe you may be able to use it with a compatible desktop PC too.
Christopher_G
Hi @Mary01
@Mary01   They are 2 separate systems that don’t work together.
