on 21-10-2023 04:17 PM
Hi there, I have 4GEE wifi mini which I am using as a wifi hub to play videogames, stream etc. I currently am playing on pc and encountered an issue when playing Warframe. Upon loading I am informed a strict NAT type is detected and the UPnP is malfunctioning. Apparently I need to forward my ports from 4950 & 4955 to 192.168.1.156 I've spent an hour researching and trying different methods to no luck so hoping someone can help. The game will run however does not allow me to join or host games.
on 22-10-2023 08:52 AM
Welcome to the community.
Does it work OK for other games? Our mobile network uses CGNAT, I'm not aware of any way to change the NAT type.
on 22-10-2023 12:03 PM
Hi @Christopher_G It does work for other games just was hoping to get back into that game as I had taken a break. That is unfortunate as I did use a public wifi and encountered no issues. I understand thank you for your help.
